Boolean Curve
Hello there,
I'm trying to use the Labs Boolean Curve sop to intersect some curves within a geo volume and it looks like the labs bool curve sop leaves a bunch of curves outside the geo volume. I tried using the "Groups" options in the sop but it doesn't separate the curves sections by the "inside" or "outside" options.
That being said, how can I keep just the curves within the geo and delete all curves outside of it?
Imgs and file attached. Thanks
Edited by Rival Consoles
Ok, I got it. I had to rotate the rectangle grid 90 degrees so the sop sees the cross section as 1 curve only. With the grid placed horizontally, from the bottom to the top, the sop would see 2 curves per cross section and will not intersect the curves correctly.
