plutonium13256 Posted August 19, 2024 Share Posted August 19, 2024 Hi all, I followed an online tutorial using the FLIP Configure Tank, and all went well. But when I tried to recreate it from scratch suddenly I get error messages. Is there a way to revert to the default settings for this node? When I tried copy pasting the same node from my previous completed file, it works. But when I call the same node form scratch I can't. Any advice would be appreciated. hou.MatchDefinitionError: Failed to match node type definition. Warning: Skipping unrecognized parameter "label1". Skipping unrecognized parameter "label2". Skipping unrecognized parameter "label3". Skipping unrecognized parameter "label4". [/obj/geo1/flipsolver1/set_boundary] Warning: This operation is only valid inside a sub-network. Error: Bad node type found: null in /obj/geo1/flipsolver1/set_boundary. Unknown operator on load "flipsolver1/set_boundary/domain". Unknown operator on load "flipsolver1/set_boundary/domain". Unknown operator on load "flipsolver1/set_boundary/domain". Bad node type found: output in /obj/geo1/flipsolver1/set_boundary. Unknown operator on load "flipsolver1/set_boundary/output2". Unknown operator on load "flipsolver1/set_boundary/output2". Unknown operator on load "flipsolver1/set_boundary/output2". Bad node type found: output in /obj/geo1/flipsolver1/set_boundary. Unknown operator on load "flipsolver1/set_boundary/output3". Quote Link to comment Share on other sites More sharing options...
