winterlang157 Posted August 24, 2024 Share Posted August 24, 2024 Hello, I'm a bit unfamiliar with Karma. Been trying to set up everything in Lops. The whole render scene works fine in viewport XPU render but when I try to render with Mplay or render to disk, karma always shows me this error "failed to rename temporary file". I've tried closing Houdini > clearing the temp folder > relaunch houdini and still same error. I've also tried it with Labs Karma, also give the same error message. I'm not sure why this is happening. Any suggestion that can solve this issue is greatly appreciated. Thank you. Extra info: I'm using Houdini 20.0.547 GPU RTX 4070 Super CPU Ryzen 7 8700G Windows 11 Quote Link to comment Share on other sites More sharing options...
