nelpiper73 Posted September 5, 2024 Share Posted September 5, 2024 Hey guys. I have a RBD sim which I want to control when constraints are generated with a custom attribute created inside a sopsolver. Problem is that when I leave the sopsolver and go back to DOP level, the a swtich I'm using to direct the stream says "local variable not recognized". I want to use the varibale DIST to trigger the creation of the constraints. So the question is how can I create a custom variable inside a sopsolver and make it available in the DOP level (one level above)? Thanks. Quote Link to comment Share on other sites More sharing options...
