doc Posted July 6, 2007 Share Posted July 6, 2007 Hi, My sop works great with Incoming attributes(eg $FOO) that have variable mappings via the "varmap" detail attribute. But if I try to us the normal attribute (which doesn't have) an associated varmap entry $NX will not work. My first inclination is to make local variables that I can associate with the special attributes (Cd, N,v, life etc), but before I did I was wondering if there's a different/better approach. Many thanks L Quote Link to comment Share on other sites More sharing options...
doc Posted July 12, 2007 Author Share Posted July 12, 2007 (edited) figured it out. setupLocalVars(); Does the trick, I was running into trouble because I need set my enum values(for the other local variables I was defing) to be something high. enum { VAR_PT=200, // Point number of the star VAR_NPT=201, etc... Apparently if you don't do this there's a conflict between your local variables and those defined by setupLocalVars(). At least I think that's what the issue was, seems to be working now. L Edited July 12, 2007 by doc Quote Link to comment Share on other sites More sharing options...
