Chops Modifications.
Kat!! you're bak!! :)
one of the way you could try would be to put down a cycle CHOP, turn on "Mirror Cycles", turn off "Blend Start to End", change the "Cycle After" (or "... Before" if that's what you want) to 1, then put down a Shift CHOP to shift it back to the origin time. There are other ways to do it, but this is what I can come up with in 30 sec without much thinking.
Hope that helped. :)
Thanks Alex, you're a genious!
