bentway23 Posted November 1, 2024 Share Posted November 1, 2024 I'm trying to apply a wetmap EXR image sequence as a texture in a Solaris/Karma material. Pointing the file name of the image node to the sequence gives me the "Cannot channels which depend on time" error. From what I've read the solution is to promote the paramater, where it shows up as an editable input on the material library. Editing that creates the edit properties node, where I can fill in the file name field. Unfortunately, that doesn't work. What do I need to do that I'm not doing? Could it simply be the syntax of the file name path needs to change to account for the $F variable? Quote Link to comment Share on other sites More sharing options...
