pbowmar Posted July 17, 2007 Share Posted July 17, 2007 Hi, In h9 it appears that I need to use a UT_Options when writing a gdp to a .bgeo or whatever. I just set this to NULL and it works fine, but as it's not documented (that I can find) I'm curious what it's used for? Cheers, Peter B Quote Link to comment Share on other sites More sharing options...
crunch Posted July 17, 2007 Share Posted July 17, 2007 Hi, In h9 it appears that I need to use a UT_Options when writing a gdp to a .bgeo or whatever. I just set this to NULL and it works fine, but as it's not documented (that I can find) I'm curious what it's used for? Cheers, Peter B It's used for passing options to the save function (of course). The only options happen to be: bool "savegroups" bool "savepointgroups" bool "saveprimitivegroups" So, you can disable saving of groups when you save the geometry. It might be used for other things in the future. Quote Link to comment Share on other sites More sharing options...
pbowmar Posted July 17, 2007 Author Share Posted July 17, 2007 It's used for passing options to the save function (of course).The only options happen to be: bool "savegroups" bool "savepointgroups" bool "saveprimitivegroups" So, you can disable saving of groups when you save the geometry. It might be used for other things in the future. Cool, thanks. Any chance of those being documented, like in the header file? Cheers, Peter B Quote Link to comment Share on other sites More sharing options...
