Ut_options Required For Gdb->save()?
Hi,
In h9 it appears that I need to use a UT_Options when writing a gdp to a .bgeo or whatever. I just set this to NULL and it works fine, but as it's not documented (that I can find) I'm curious what it's used for?
Cheers,
Peter B
  pbowmar said:
Hi,
Cheers,
Peter B
It's used for passing options to the save function (of course).
The only options happen to be:
bool "savegroups"
bool "savepointgroups"
bool "saveprimitivegroups"
So, you can disable saving of groups when you save the geometry.
It might be used for other things in the future.
bool "savegroups"
Cool, thanks. Any chance of those being documented, like in the header file? :)
Cheers,
Peter B
