Simon Yang Posted November 13, 2024 Share Posted November 13, 2024 "Do you know how to insert arbGeomParams in a specific location to export a particular detail value?" This is maya to houdini alembic original file. ============================================================ Hierarchy in Alembic File: Object: ABC Property: .childBnds Property: statistics ScalarProperty: statistics Sample 0: PolyAnimNum 202 PolyAnimCVs 224681769 PolyAnimFaces 618863 TransStaticNum 266 Property: 1.samples ScalarProperty: 1.samples Sample 0: 351 Object: robotarm:robotarm Property: .xform CompoundProperty: .xform Property: .arbGeomParams #----------------------------------------------------------- CompoundProperty: .arbGeomParams Property: ver <--------- Property: .userProperties CompoundProperty: .userProperties #----------------------------------------------------------- ============================================================ This is houdini to maya export alembic original file. ============================================================ Object: robotarm:robotarm_hi_lf_part_a_metal_a Property: .xform CompoundProperty: .xform Property: .inherits ScalarProperty: .inherits Sample 0: True Property: .ops ScalarProperty: .ops Sample 0: 48 Property: .vals Property: visible ScalarProperty: visible Sample 0: -1 Object: robotarm:robotarm_hi_lf_part_a_metal_aShape # ------------------------------------------------- Property: .geom CompoundProperty: .geom Property: .selfBnds Property: P Property: .faceIndices Property: .faceCounts Property: .arbGeomParams CompoundProperty: .arbGeomParams Property: ver_test ScalarProperty: ver_test <------------ Sample 0: v777 Property: uv CompoundProperty: uv Property: .vals Property: .indices Property: N Property: visible ScalarProperty: visible Sample 0: -1 # ------------------------------------------------- Object: robotarm:robotarm_hi_lf_part_a_metal_b ============================================================ I have a path primitive value in Houdini, with Build Hierarchy From Attribute checked in the ROP Alembic Output node, and Path Attribute set to path for export. I'm exporting a ver_test detail attribute, and I want to attach this detail value to robotarm:robotarm, matching the original .abc file that came from Maya. Does anyone know how to do this? help.... ~~ Quote Link to comment Share on other sites More sharing options...
