maximumseat Posted November 18, 2024 Share Posted November 18, 2024 Same skeleton, same skin. I've got boneCaptureA coming from an attribute transfer and boneCaptureB coming from a biharmonic capture. How would one combine the 2 into a single bone capture using a painted mask to define where to use which? Someone suggested the capture override sop might do what i'm after but i can't find any real information on how to use it. Attribute combine definitely doesn't work and using a capture attrib unpack and lerping the boneCapture_data values in a wrangle doesn't seem to work either because the amount of bones influencing each point seems to change from capture to capture. Anyone got any ideas on how i can pull this off? Quote Link to comment Share on other sites More sharing options...
maximumseat Posted November 18, 2024 Author Share Posted November 18, 2024 there also seems to be a blend factor on the bone capture biharmonic, but it doesn't appear to accept point attributes? Quote Link to comment Share on other sites More sharing options...
