VEX Error: Preloaded shader is invalid
Hey, Guys!
I have error with  common Houdini vex based HDAs, like Attribute Blur: Preloaded shader is invalid.
Houdini reinstallation didn't help(
If dive inside we can see problem starts from "init_target_attribs"
Any idea whats going on and how to fix it?
Solution For those who have the same problem:
problem was in compiling vex snippets/scripts and you can fix it removing vex compiling directory. Example path C:\Users\User\AppData\Local\Temp\houdini_temp\VEX_CodeCache
