Tomoka Posted November 28, 2024 Share Posted November 28, 2024 (edited) Hi, I’m currently working in Houdini and trying to rotate a non-perpendicular primitive to align it with the X-axis. In the second image, I used a Transform node and manually adjusted the rotation to achieve the alignment. Is there a procedural or more accurate way to achieve this? Any tips, improvements, or alternative approaches would be greatly appreciated. Thank you! Edited November 28, 2024 by Tomoka Quote Link to comment Share on other sites More sharing options...
toadstorm Posted November 28, 2024 Share Posted November 28, 2024 given two points on the long edge of the rectangle, let's say they're point 0 and 1: vector p0 = point(0, "P", 0); vector p1 = point(0, "P", 1); vector n = normalize(p0 - p1); // compute matrix that rotates the normalized edge onto +X matrix3 d = dihedral(n, {1,0,0}); // transform points with this rotation @P *= d; 2 2 Quote Link to comment Share on other sites More sharing options...
Tomoka Posted December 1, 2024 Author Share Posted December 1, 2024 It worked! Thank you so much! Quote Link to comment Share on other sites More sharing options...
