pbowmar Posted July 26, 2007 Share Posted July 26, 2007 Hi, I have a GDP of points. I want to copy metaballs to it and create a new GDP containing the copied metaballs. Exactly like wiring a Metaball SOP into the left side and some points to the right side of a Copy SOP. Ideally using "pscale" to scale the metaballs just like the Copy SOP. I'm very lost on how to create the Metaballs, I see multiple classes that relate to/create metaballs. Do I use GU_PrimMetaBall? Any examples gratefully received. Note that I'm ultimately feeding this GDP into GU_SDF to create an SDF, if that makes any difference... Cheer,s Peter B Quote Link to comment Share on other sites More sharing options...
pbowmar Posted July 26, 2007 Author Share Posted July 26, 2007 OMG!! It's documented!! I just about had a heart attack... Quote Link to comment Share on other sites More sharing options...
TheUsualAlex Posted July 26, 2007 Share Posted July 26, 2007 aah cool! that's good news. which header were you looking at again..? Quote Link to comment Share on other sites More sharing options...
pbowmar Posted July 26, 2007 Author Share Posted July 26, 2007 aah cool! that's good news. which header were you looking at again..? GU_PrimMetaBall.h is the one. The docs are in a little HTML in the html directory. I can't figure out GU_Copy.h though, anyone used this? I can get around it by looping through my seed points and creating a new metaball on the point but I would have thought there would be a straightforward Copy way to do it... Cheers, Peter B Quote Link to comment Share on other sites More sharing options...
