Lampay Posted December 12, 2024 Share Posted December 12, 2024 Hey Houdini wizards! I'm currently working on an HDA (still in the process of building the parameter interface, so it's not fully finished yet). I’d like to know how I can use a toggle (on/off button) created in my HDA to control the Display > Optimization > Back Face parameter. The goal is to be able to turn this parameter on and off directly from my HDA, without having to open the display settings each time. I’ve tried solving this with ChatGPT, but the suggested solutions and Python scripts didn’t work for me. I’m using Houdini version 20.5.332. Thanks in advance for your help! Any suggestions, scripts, or guidance would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
Fenolis Posted July 13, 2025 Share Posted July 13, 2025 (edited) Check the docs, they're factually correct, unlike ChatGPT: https://www.sidefx.com/docs/houdini/hom/hou/GeometryViewportDisplaySet.html def TintBackface(): node = hou.pwd() bTintBackface = node.parm("tintbackface").evalAsInt() # Get a reference to the geometry viewer pane = hou.ui.curDesktop().paneTabOfType(hou.paneTabType.SceneViewer) # Get the display settings settings = pane.curViewport().settings() # Get the GeometryViewportDisplaySet for objects dispset = settings.displaySet(hou.displaySetType.DisplayModel) dispset.showPrimBackfaces(bTintBackface) Edited July 13, 2025 by Fenolis video cut off important bit, removed Quote Link to comment Share on other sites More sharing options...
