sadjadalavi Posted December 31, 2024 Share Posted December 31, 2024 Welcome to this Houdini project! With this project, you will learn how to create strong wind effects on branches, leaves, and other objects in a very simple and optimized way. You will also learn how to move leaves on the ground and create a storm scene like the one in the image. This project is ready to use. You just need to press Shift + V to get the final result. All the settings for rendering and fog are already set up in Karma. Also, with this project, you will get three useful digital assets that can help you in your other Houdini projects. Let’s start and create the storm together! Hip file : https://sajadalavi.gumroad.com/l/hzece Quote Link to comment Share on other sites More sharing options...
