bentway23 Posted January 4, 2025 Share Posted January 4, 2025 (edited) I have a background image attached to a camera that is slightly offset, maybe 2% off but enough to cause a problem. The culprit is apparently in the display settings--when I turn off "Apply Zoom to Background" it works as it should. (I'm auto-placing it for precision--it's the same dimensions as the camera so fill, horizontal, vertical all do the same, and it's too hard to line up the values manually to not auto-place it.) The problem is that as soon as I click away and on to something else, Apply Zoom comes back, checked in the dialogue box and messing up my image. How can I make it stay off? The camera is an alembic, tracked in and imported from Blender--I'm guessing there's some sort of thing I need to tick to compensate. If I create a new camera the bg image lines up fine, so it has something to do with the imported camera. (In Blender, the imported camera works fine with the background image--it lines up perfectly.) Edited January 4, 2025 by bentway23 added info Quote Link to comment Share on other sites More sharing options...
bentway23 Posted January 4, 2025 Author Share Posted January 4, 2025 Found it, in case someone else runs into this: in the imported camera's properties (within the Alembic xform subnet)there are "screen window x/y" parameters, which were purple. I removed the expressions and replaced them with 0 and now it lines up just right! 1 1 Quote Link to comment Share on other sites More sharing options...
