Getting A Progress Bar In Hscript
vfx-ger
I don't think you can. If you are running hscript commands in the textport you can use echo to track its progress but that's about all. Other than that you'd have to hack something with a parameter that you increment using opparm....
Most hscripts finish pretty quickly maybe what your trying to do can be achieved another way if its taking so long it needs a progress bar.
It's only really slow if you echo one line at a time. I generally concatenate a thousand or so lines into a single string, and echo it all at once. It seems to be about, well, a thousand times faster.
True, I may venture into the HDK. I was using a hscript to output to a file using the indirect arrows (>> and >) and echo which will always be far too slow.
Thanks.
