delete force impact from relationship geometry
Kaito Ishikawa
Hi.
I am trying to create a building destruction. I want to destroy only the pillars by force.
However, the relationship_geometry in the sop solver in the dop now inherits the impact, which was not there before, and the destruction can no longer be controlled.2025-02-20194124.thumb.png.54525eb610f84839b2954a420674d54f.png
I tried to delete the attribute delete after the relationship_geometry, but the machine did not work well as the constraint moved slightly every frame.
I used to be able to cleanly marble only the columns, but now I can't reproduce them.
I add the tutorial I was going to do and the current files.
https://youtu.be/Sv11Iha4Sfc?feature=shared
destruction_building_v01.hipnc
+ I tried to destroy it with velocity by removing some of the constraint without using force, but for some reason, the relationship_geometry generated force and impact!
Please let me know if you know.
Thanks,
Kaito Ishikawa
Edited by Kaito Ishikawa
