How To Render Fluid Object In Dop ?
How to render fluid object in DOP ?
what you have to do is use the dop import sop, and specify what Geometry Data Path you wish to use
in the case with liquid, use : surface/Visualization
A good example of this is from the Fluid shelf, just use the Liquid Container, and that will show you a easy work flow.
hope this helps
