Tamis Posted October 10, 2007 Share Posted October 10, 2007 is it posseble to use the metaballs volune inside a shader ?? if been tryng but i can only use it as a image 3d. Quote Link to comment Share on other sites More sharing options...
aracid Posted October 10, 2007 Share Posted October 10, 2007 hey man if you wish to render the metaballs as volume (similar to i3d ) - in the case of rendering volume : take a look at Help documention under /rendering/volumetricrendering - search for "Rendering Metaballs" at the bottom of the page shows an example. however if u want to access data from the mataballs, within ur shader, look at the metaimport vop. a good example is found in the FX tools, thick smoke, the VOP shader and VOP SOP uses the metaimport vop, and that allows you to read data on ur shader. hope this helps Quote Link to comment Share on other sites More sharing options...
Tamis Posted October 10, 2007 Author Share Posted October 10, 2007 Thats exacly what i'm looking for metaimport. only i can't find the thick smoke example is this still apparent in the houdini 9 documentation ?? any way geat thanks for helping me here, i hope to be of service to you one day. hey manif you wish to render the metaballs as volume (similar to i3d ) - in the case of rendering volume : take a look at Help documention under /rendering/volumetricrendering - search for "Rendering Metaballs" at the bottom of the page shows an example. however if u want to access data from the mataballs, within ur shader, look at the metaimport vop. a good example is found in the FX tools, thick smoke, the VOP shader and VOP SOP uses the metaimport vop, and that allows you to read data on ur shader. hope this helps Quote Link to comment Share on other sites More sharing options...
aracid Posted October 11, 2007 Share Posted October 11, 2007 Thats exacly what i'm looking for metaimport.only i can't find the thick smoke example is this still apparent in the houdini 9 documentation ?? check out the FX tools here Sesi's FX Tools hope this helps Quote Link to comment Share on other sites More sharing options...
