Taking The Max Attribute Of A Point In A For Loop
shikung444
Hi everyone,
I'd like to iterate through a for loop inside a vopnet, and take the maximum attribute value for any point through all the iterations. Please check out the attached file, I think you'll understand what I'm trying to do.
I'm trying to create the same type of volume select as in 3ds max, where a mesh can select pieces of another mesh based on bounding and including a falloff region.
This could possibly be done with an attribute transfer method, but I'd like to test this method as well.
Thanks!
falloff_B.hip
Edited by shikung444
Hi everyone,
Thanks!
why is not vop network?
when I open, it convert vopsop1 to merge sop.
I wanna see inside vop network.
