Matt.b Posted August 7, 2025 Share Posted August 7, 2025 Hello everyone, I'm new to Houdini and the website, but I need your help because I'm trying to create a Vellum simulation on top of another simulation. Long story short, my first simulation looks like this: (Sorry, I don't know how to use an image with a URL) https://gyazo.com/329da84689ed8f3da1b8ea85b995d136 Then I run it in a for each loop so I can refract each piece while maintaining the animation. With an exploded view, I have this: And now, where I'm having trouble: https://gyazo.com/65823f02b1649f19353f8e93a6fd8582 I want to rerun a Vellum simulation that will make each fragment fly with the popwind. To do this, I've already defined propagation attributes. I simply want the parts to follow the first simulation until the "activate" attribute is equal to 1. Then, each part with attribute 1 becomes independent of the simulated mesh. I don't know if this is clear, sorry, I've been on this for 4 days with ChatGPT and a tutorial, but I can't figure it out. I've tried many parameters and a lot of VEX code like this. https://gyazo.com/67d219f2edca7dbd09fcf78a80ce645d https://gyazo.com/4fef09ea1b1d2685c781a6217170ff95 This is the simplest test I've done. There are others in the .hip, but I got the closest results. I don't know why these points disappear. But with another configuration, I got simulations like this. they take too long to cache so i can't show you the 100+ frame, But yesterday with a setup I managed to make each piece fall according to the activate attribute, but the pieces that did not have activate at 1 therefore stopped at 0, did not follow the movement of my basic simulation, I hope that someone will have the faith and the time to help me, thank you Quote Link to comment Share on other sites More sharing options...
albehany Posted October 7, 2025 Share Posted October 7, 2025 I have same issue and looking for solution for this. Quote Link to comment Share on other sites More sharing options...
