Rudra Posted January 3, 2008 Share Posted January 3, 2008 Hi! How can I proceduraly delete garbage primitives after trace sop? Or can I avoid them? Thanks! Quote Link to comment Share on other sites More sharing options...
zoki Posted January 4, 2008 Share Posted January 4, 2008 hi depends on what you call garbage primitive:) what you want to keep you can add measure- area and then delete according to area size so you get rid of all small or all big primitives depending on their area size You can select manually primitives with select connected switched on also check cmifx procedural cities dvd because david is doing the same there z Quote Link to comment Share on other sites More sharing options...
Rudra Posted January 4, 2008 Author Share Posted January 4, 2008 Hi, Zoki! I wanted to keep lines. If I turned on hole faces, I got all primitives marked with red dots. But I want to delete them procedurally. So delete sop isn't a good stuff for this task. And measure sop too, cause white lines is an individual primitive and I don't know how to distinguish areas of "white line" primitive and all others areas. They can be equale Quote Link to comment Share on other sites More sharing options...
zoki Posted January 4, 2008 Share Posted January 4, 2008 i cant check for sure now but i think it is possible to get cd color attribute from cops on geo and then you can select geo according to color value? just an idea ? z Quote Link to comment Share on other sites More sharing options...
Rudra Posted January 4, 2008 Author Share Posted January 4, 2008 Yeah) Nice idea. I'm trying such stuff right now. Quote Link to comment Share on other sites More sharing options...
