How to Render Multiple Cameras Sequentially in One Karma Render (Solaris)
In my Houdini Solaris scene, I have three cameras with different frame ranges:
cam1: frames 48–96
cam2: frames 24–140
cam3: frames 120–200
I want to render them sequentially (one after another) using Karma — but all in a single render submission.
In other words, I want to press “Render to Disk” once and have it automatically render cam1, then cam2, then cam3, each with its own frame range and output path.
Is there a way to set this up directly in Solaris without having to manually render each camera separately?
2 hours ago, kiko said:
There are several way you can achieve that. Take a look at the multi-shot workflow section of this video
I personally set this up in TOPs  using ROP Fetch node and Merge.
Thank you so much, this is exactly what I need.
