New Mind Posted October 19, 2025 Share Posted October 19, 2025 In my Houdini Solaris scene, I have three cameras with different frame ranges: cam1: frames 48–96 cam2: frames 24–140 cam3: frames 120–200 I want to render them sequentially (one after another) using Karma — but all in a single render submission. In other words, I want to press “Render to Disk” once and have it automatically render cam1, then cam2, then cam3, each with its own frame range and output path. Is there a way to set this up directly in Solaris without having to manually render each camera separately? Quote Link to comment Share on other sites More sharing options...
kiko Posted October 19, 2025 Share Posted October 19, 2025 There are several way you can achieve that. Take a look at the multi-shot workflow section of this video I personally set this up in TOPs using ROP Fetch node and Merge. Quote Link to comment Share on other sites More sharing options...
New Mind Posted October 19, 2025 Author Share Posted October 19, 2025 2 hours ago, kiko said: There are several way you can achieve that. Take a look at the multi-shot workflow section of this video I personally set this up in TOPs using ROP Fetch node and Merge. Thank you so much, this is exactly what I need. Quote Link to comment Share on other sites More sharing options...
