SantiX Posted February 13, 2008 Share Posted February 13, 2008 Hi.. This is my first post in the forum. I'm doing a very simple fluid simulation with a Sphere a the Source and a funnel as the collision geometry. I already have the the collision object set to 120 divisions but I still see fluid interpenetration with the geometry. Some times the fluid would just stop and do nothing. Any idea what could be causing this?? Attached is the file Thanks SantiX funnel_test1.hipnc funnel_test.mov Quote Link to comment Share on other sites More sharing options...
digitallysane Posted February 13, 2008 Share Posted February 13, 2008 Hi.. This is my first post in the forum. I'm doing a very simple fluid simulation with a Sphere a the Source and a funnel as the collision geometry. I already have the the collision object set to 120 divisions but I still see fluid interpenetration with the geometry. Some times the fluid would just stop and do nothing. Any idea what could be causing this?? Attached is the file Thanks SantiX Seems your volume representation of the funnel is not accurate enough: http://www.sidefx.com/docs/houdini9.1/dynamics/collisions Dragos Quote Link to comment Share on other sites More sharing options...
pclaes Posted February 13, 2008 Share Posted February 13, 2008 Not enough detail in collision volume, extrude the surface of that cup outwards a bit. Or make the funnel into a solid object (like a cylinder) and subtract from a box with a cookie, use the resulting geometry as a collision object in dops. Either way you end up having enough volume for the collision. Quote Link to comment Share on other sites More sharing options...
SantiX Posted February 14, 2008 Author Share Posted February 14, 2008 Thank you guys.... I remodeled the funnel with the cookie sop as pclaes suggested, and it seems to be working fine now. But I don't see why was it interpenetraiting before. The geometry had more detail, and more subdivisions for collisions than the one I'm using right now. Thanks again! Quote Link to comment Share on other sites More sharing options...
