Exporting Fractured Rbd To Sops
august
Hello.
I have a fractured rbd object that I'm trying to transfer back to sops.
I can create an object_merge node and maunally load each object. This sucks because if I change the number of objects, I have to re-edit all the entries.
`stamps("../OUT", "DATAPATH", "/obj/dopnet1:shardGroup0/Geometry")`
There _has_ to be an better way to do this.
The main problem I can't figure out is how to get an expression to cycle through all of the objects in the rbd_fracture_object.
dopoption("/obj/dopnet1", "shardGroup0", "Position", "tx")
How can I make this evaluate not just shardGroup0, but the other 15 shards?
I have the copy sop that creates the group names. Using another copy sop I can use the above dopoption expression to get 1 object at a time. Which is the same problem.
Thanks for any help.
