CodeMasterMike Posted March 11, 2008 Share Posted March 11, 2008 Hello! Now, I have constructed a working standalone exporter. And I need to get the string (address) that you chooses when rightclicking on the geometry and chooses "save geometry". The inputs you get in the initial function is: int main(int argc, char *argv[]) { ........ } and what I have found in other examples (such as in: Loading and Saving Geometry in Houdini Tools) they use something like: m_GUDetail.load(cin); ofstream LoadStream(argv[1]); LoadStream << "Write this into the file"; Now, this would work fine if I use the ofstream, created above. But since I am exporting to a closed special fileformat (*.nmo), I have to use the nmo files specific file save function, so I cant use the above code to save the file. Looking at the "argv[1]" string, this one is pointing to a temp address (not the final place where the file will appear). And "argv[0]" only says the standalone program title. So I was wondering if there is a way to retrieve the address (which surley must be a input value from houdini?) and use that one in my own specific saver function? Quote Link to comment Share on other sites More sharing options...
CodeMasterMike Posted March 14, 2008 Author Share Posted March 14, 2008 I asked in the sidefx forum aswell about this, since it seemed that noone here knew it. So I got a reply from a person 'mtucker' which explained it very well! Here is the reply But I will also cut and paste in the reply below: As for cin, that's just the C++ stream representing stdin. When Houdini uses an external application for geometry conversion (using the GEOio table, which I assume is what you're doing), it opens the application with a pipe, and sends the Houdini formatted geometry through stdin. As for writing out the file, you are doing the right things by saving to the file whose name is passed in as argv[1]. Yes, this is a temp file. The reason for this is that Houdini can do some stuff that your app can't. For example, in Houdini you can specify "opdef:Object/myobj?somename" as a location to save a file. Your app would have no idea how to deal with that. So Houdini insultes your app by always letting you save to a nice local temp file. Houdini then copies that temp file to the actual requested save location, and deletes the temp file. So you're doing the right thing with the way you're saving the file. Houdini will take care of the details. Quote Link to comment Share on other sites More sharing options...
