Deforming wire
Zanozza
  • 3 weeks later...
Hi!
I think you mean a wire, that after being hit by something doesn't spring back to the initial pose, but to a pose that is deformed by the hitting object?
If you don't need the deformation to occur in simulation but can fake this pretty easily by animating the rest geometry (don't forget to switch "Use Deforming Geometry" on for your wire node). If it has to occur within simulation, you'll probably have to somehow automatically feed the simulated geometry deformation back into the rest geometry, not sure how to do that.
Best
Timm
