MENOZ Posted March 22, 2008 Share Posted March 22, 2008 hello. what is the difference fom edit parameter interface of a node from the parameter pane, or RMB on the node and Type properties, and edit the parameter tab? the param tab of type properties works only on digital assets. can you explain me? thank you! Quote Link to comment Share on other sites More sharing options...
Vormav Posted March 22, 2008 Share Posted March 22, 2008 MENOZ said: hello. what is the difference fom edit parameter interface of a node from the parameter pane, or RMB on the node and Type properties, and edit the parameter tab? the param tab of type properties works only on digital assets. can you explain me? thank you! Type properties is used to change the permanent parameters of a node - the parameters that will be there with every single new instance of the node that you use. 'Edit parameter interface' only changes the interface of a single instance of the node. It's basically the new way of adding "spare parameters." Quote Link to comment Share on other sites More sharing options...
MENOZ Posted March 23, 2008 Author Share Posted March 23, 2008 Vormav said: Type properties is used to change the permanent parameters of a node - the parameters that will be there with every single new instance of the node that you use. 'Edit parameter interface' only changes the interface of a single instance of the node. It's basically the new way of adding "spare parameters." oh thank you! Quote Link to comment Share on other sites More sharing options...
