killdom Posted May 2, 2008 Share Posted May 2, 2008 hi i am learning houdini,I have some quesionts about some expressions function of chop,such an `ic(input_index, channel_index, index)`.What does input_index, channel_index, and index mean?what's the differents betwine the input_index and channel_index? thanks in advance. Quote Link to comment Share on other sites More sharing options...
andrewlowell Posted May 2, 2008 Share Posted May 2, 2008 (edited) The expression CHOP is definatly the most powerful CHOP in the CHOPs toolset. Although I hope they eventually get a Python CHOP like the Python SOP definition. Anyway here's how it works. the expression ic(0,$C,$I) is the same thing as typing in $V 0 means read from the first input of the CHOP $C means read from the current channel, like tx0 or tx1 and $I means the current sample index, in this case think of it like the current time, although it's more specific than that. ------------------------- this CHOP will always output the same number of channels as it's 0ith input. So, if you had 3 channels tx0,ty0,tz0 going into the first input, it wouldn't matter how much other stuff was connected to it, you'd still get three channels going out ... what you do with those channels is up to you however. Here's what I mean. ----------------------- Say you wanted to overwrite those channels with the second input, so instead you'd enter ic(1,$C,$I) ... then it would essentially copy the second CHOP input onto the output. or maybe you had three CHOPS and wanted to blend between the second and third inputs ... maybe something cool like this ic(floor(sin($I))+1,$C,$I) ----------------------------------- Maybe instead of selective reading you want to time stretch .. so here's how you'd slow it down by half ic(0,$C,$I/2) ---------------------------------------- The possibilities are numerous, oc() can make CHOPs function recursivly like particles by reading the output channel for the next cook. -------------------------------------- hi i am learning houdini,I have some quesionts about some expressions function of chop,such an `ic(input_index, channel_index, index)`.What does input_index, channel_index, and index mean?what's the differents betwine the input_index and channel_index? thanks in advance. Edited May 2, 2008 by andrewlowell Quote Link to comment Share on other sites More sharing options...
killdom Posted May 3, 2008 Author Share Posted May 3, 2008 The expression CHOP is definatly the most powerful CHOP in the CHOPs toolset. Although I hope they eventually get a Python CHOP like the Python SOP definition. Anyway here's how it works.the expression ic(0,$C,$I) is the same thing as typing in $V 0 means read from the first input of the CHOP $C means read from the current channel, like tx0 or tx1 and $I means the current sample index, in this case think of it like the current time, although it's more specific than that. ------------------------- this CHOP will always output the same number of channels as it's 0ith input. So, if you had 3 channels tx0,ty0,tz0 going into the first input, it wouldn't matter how much other stuff was connected to it, you'd still get three channels going out ... what you do with those channels is up to you however. Here's what I mean. ----------------------- Say you wanted to overwrite those channels with the second input, so instead you'd enter ic(1,$C,$I) ... then it would essentially copy the second CHOP input onto the output. or maybe you had three CHOPS and wanted to blend between the second and third inputs ... maybe something cool like this ic(floor(sin($I))+1,$C,$I) ----------------------------------- Maybe instead of selective reading you want to time stretch .. so here's how you'd slow it down by half ic(0,$C,$I/2) ---------------------------------------- The possibilities are numerous, oc() can make CHOPs function recursivly like particles by reading the output channel for the next cook. -------------------------------------- I really appreciate all your help.Thanks very much. Quote Link to comment Share on other sites More sharing options...
