i3d instancing problem
nnnnn
Does anyone know of a way to instance an I3D volume onto a particle system (about 1000 particles)
so that the volumes inherit the particles color,
without using the Copy SOP.
I tried it with the Copy SOP, but it consumes way too much mem and takes a long time to render.
On the other hand, instancing a single i3d volume obj (just a IsoSurface SOP -> Material SOP network), is both time and mem efficient,
but it does not inherit the point color of the template obj.
And here is a "gotcha",
if the i3d volume obj doesn't have a material (ie: wispy smoke)
it is instanced as a shiny plastic surface, not a volume.
Any ideas??????
Thanks in advance.
Edited by nnnnn
