Hello Metacloud
Guest Swann
Guest Swann
Hello everybody
I'm trying to recreate standard Houdini MetaCloud shader in VOPS and I got some questions. These are only my thoughts about what to do.
* Produced by:
* Side Effects Software Inc
* 123 Fronst Street West, Suite 1401
* Toronto, Ontario
* Canada M5J 2M2
* 416-504-9876
* NAME: fluffy.vfl ( VEX )
* COMMENTS: Generate a fluffy cloud using metaball geometry
#pragma opname v_metacloud
#pragma oplabel "VEX Meta Cloud"
#pragma label freq "Noise Frequency"
#pragma label offset "Noise Offset"
#pragma label time "Cloud Time"
#pragma label amp "Noise Amplitude"
#pragma label rough "Noise Roughness"
#pragma label turb "Turbulence"
#pragma label limit "Density threshold"
#pragma label perpoint "Per-point noise"
#pragma label summing "Density"
#pragma hint perpoint toggle
#pragma range turb 0 8
#pragma choice summing "sum" "Sum metaball densities"
#pragma choice summing "max" "Choose maximum density"
#pragma range turb 0 10
Content of this part is pretty clear for me :)
// Compute noise on a per metaball basis. We take either the max or the sum of
// the densities.
vector
compNoise(vector p; vector freq, off, amp; float rough, now; int turb)
int i;
vector scale;
vector nval;
vector4 pp;
pp = p * freq + off;
pp.w = now;
nval = 0;
scale = amp;
for (i = turb; i-- > 0; pp *= 2, scale *= rough)
nval += scale * (vector(noise(pp)) - (.5,.5,.5));
return nval;
In the gNoise.h there are couple similar noise functions, althrough not identical so I supose it will be best to go here with InlineVOP. But using oportunity that OldSchool started in his BLOG series of lessons on "Create Custom VOP" I thinking about recreating this function clearly in VOPs without InlineVOP.
Question 1:
1. pp.w //does this mean "dot produkt per-point and w " ?
2. pp *=2 or nval += //what mean sign * and + before # equal ?
image3d
metacloud( vector freq=3; // Noise frequency
vector offset=0; // Noise offset
float time=0; // Time offset
vector amp=.3; // Noise amplitude
float rough=.6; // Noise roughness
int turb=4; // Turbulence
float limit=1; // Maximum density
int perpoint=0; // Do per-point noise calc
string summing="sum"; // Do summing by default
no questions here yet
vector nval;
vector pp;
float tmp;
density = 0;
if (perpoint)
forpoints(P)
// Convert to the space of the metaball. Now, P is somewhere in
// the unit sphere.
pp = mspace(P);
1.
- starting from globalVariablesVOP
- density plug to compareVop
- to InlineVOP we pluging Globals "P" and output of compareVOP
- output of InlineVOP will give "nval"
2.
- nval, P, and compareVOP we are pluging to If-Then-BlockVOP
3. inside If-Then-BlockVOP:
- P and nval plugged into pointLoopVOP
4. inside pointLoopVOP
- "pp" it's P after transform to metaball space with a help of metaBallSpaceVOP
// Now, if there's a rest attribute, add it onto the original
// position. This gives us a per-metaball noise offset.
if (isbound("rest"))
pp += mattrib("rest", P);
- propably we can supply "rest" attribute with parameterVOP and add it to P (Question 2: There is written original P, so does this mean big P not the "pp" after transform ?) but we cando the same with a help metaBallAttributeVOP whitch by deflaut is looking for "rest" attribute
Question 3: What means pp+ ? Is it mean the same what normal "pp" and plus means that something is added (rest attribute) to it ?
Question 4: beside, like below with "P+nval", maybe "pp+" should be done by adding output of metaBallAttributeVOP and metaSpaceVOP
nval = compNoise(pp, freq, offset, amp, rough, time, turb);
tmp = mdensity(P + nval);
- we got "nval" but "tmp" hm... with this I got problem, because:
Question 5: There is written "P+nval" and metaDensityVOP is not taking nval in his calculations, so what should I do ? instead metaDensityVOP make addition of big "P" and "nval" ?
if (summing == "sum")
density += tmp;
if (density > limit)
break;
else if (tmp > density)
density = tmp;
break;
else
// Just compute noise in world space
nval = compNoise(P, freq, offset, amp, rough, time, turb);
density = mdensity(P + nval);
density = clamp(density, 0, limit);
- we leave this part for now, I don't have idea how to remade most of this, proplably next if-Then-BlockVOP but I completly don't know how to bite "density > limit", "break" and others here.
Question 6: beside, why in the end we are calculating noise in worldSpace ( when condition is not meet) when we need it calculated in metaSpace ?
Thanks
Edited by SWANN
Hey
I'll try give it a shot,
Q:
A: normally when u define a vector 3 you have 3 floats paired to the variable, vector.x vector.y vector.z
in the case of a vector4 u have an aditional float called w, which i think stands for weight, but u can store any float with.
so theres nothing special involved except with a float u store 1 value, a vector - 3 val, vector4 - 4 val.
Q:
A:
pp*= 2 actually expands to pp = pp * 2.
or in the case of pp+= 2 expands to pp = pp + 2;
so its just a more efficient method of coding.
Q:
A:
thats purely because they haven't included a method to introduce the local translations of each metaball.
I think for no reason expect as an example of a simple shader that doesn't include much.
Take a look at the heavy smoke in the FX shelf, included with that is a shader that uses the local space of the metacloud as a coordinate system.
hope any of this was helpful.
:blink:
Guest Swann
Hey
Q:
Q:
A:
Q:
A:
Thanks, it clears some fog from my eyes
:blink:
Yeah, thanks again, I see how break and clamp should be done
Edited by SWANN
Guest Swann
I forgot that this shader calculates two types of smoke, per-point and normal and this is the reason why it calculates in the end smoke in worldSpace, just to make swimming effect for the smoke-cloud type.
Edited by SWANN
