ykcosmo Posted June 11, 2008 Share Posted June 11, 2008 I installed fftw3 and tried to compile ocean toolkit rc3 I installed the fftw3 as: ./configure --enable-float so it has the fftw3f, but when I compile, it said: Linking with 'libblitz' Linking with 'libfftw3f' Making SOP_Ocean.o and /home/kosmo/houdini9.1/dso/SOP_Ocean.so from SOP_Ocean.C /usr/lib64/gcc/x86_64-suse-linux/4.2.1/../../../../x86_64-suse-linux/bin/ld: /usr/local/lib/libfftw3f.a(execute.o): relocation R_X86_64_32 against `a local symbol' can not be used when making a shared object; recompile with -fPIC /usr/local/lib/libfftw3f.a: could not read symbols: Bad value collect2: ld returned 1 exit status Then I modified the fftw3f to fftw3 in the compile.sh, it worked fine, but when I connect the grid into ocean sop, it shut down houdini and said: ~/houdini9.1/9.1.260/dso/SOP_Ocean> /opt/hfs9.1.260/bin/houdini-bin: symbol lookup error: /home/kosmo/houdini9.1/dso/SOP_Ocean.so: undefined symbol: fftwf_plan_dft_c2r_2d I use opensuse 10.3 64bit Quote Link to comment Share on other sites More sharing options...
ykcosmo Posted June 11, 2008 Author Share Posted June 11, 2008 ok, after I i install the fftw3 as --enable-shared, it works now. Quote Link to comment Share on other sites More sharing options...
