transfer color texture to points
MENOZ
hello
i need to arrange some points on a sphere. they should exist only where my texture is white.
so i have my sphere with a black and white texture. i scatter some points on my sphere, then i want to delete the points wich fall on black areas of my sphere.
i can assign a texture to a sphere, and scatter points, but i don't know how to pass texture information to points.
can you help me please?
thank you
Hey
Try using the tex expression in a point sop, then a delete sop to prune the points u dont need.
float tex (string filename, float U, float V, string color_type)
Textures can be 1, 3 or 4 channel images containing 8-bit, 16-bit or floating point data.
tex("Mandril.pic", $BBX, $BBY, r)
in their example they use Bounding X and bounding Y to look up the texture,
you would probably need $MAPU $MAPV too lookup ur coordinates.
hope this helps
  • 5 years later...
Hey guys,
This is noob q. but is there a way i can get this to work without using the uvtexture sop?
Ive got a mesh with its own uvs...  and it seems it only works with the texture type @ orthographic. :wacko:
I've been working in houdini for about a month so its prob something really basic that im missing.
