aspect Posted July 14, 2008 Share Posted July 14, 2008 hi all, i'm exploring the houdini capacity in meshing pattern for polygon, seems to me there are limitations- 1. when i use the "divide" sop for a polygon box, divide>smooth polygon>weight.... since i want to have a variation for the "weight" apply to different surface of the box, i tried to type in expression like $PT+... , however, houdini do not allow me to do so. I then tried to use attribcreate for the "weight",still do not work. 2. since all the lines are straight in a polygon meshing, is there any way to select individual lines to make it as a curve? i tried to isolate the edge and make it polyspline, however i cannot merge it back to the original surface to be part of the primitive divisions. Please see here- http://farm4.static.flickr.com/3275/266741...ecd4d2426_o.jpg 3. when i use "divide">convex polygons or "tristrip" sop, is there any way to control the trianglation directions at selected primitives? thanks! herman Quote Link to comment Share on other sites More sharing options...
