Object Merge: geometry many times bigger/smaller.
paleajed
Hi
go inside obj/elephant
on object_merge1 - under the parameters, u'll see a transform menu -- urs is set to "specified object" and it needs to be set too "into this object"
you basically making sure that the transformations that have been done to the object gets applied onto the object u're bringing in.
hope this helps
