STREE_feathery.h
sine
for any shader do i need a library STREE_feathery.h, where it can be found?
It was probably a shader written using ShadeTree [wayback machine] -- kind'a like VOPs but for RenderMan/MentalRay (which is no longer available). I'm afraid that unless you happen to own an old cut of ShadeTree, you won't have access to "STREE_feathery.h".
Guest xionmark
Here ya go:
float STREE_feathery(vector p; float freq, it;)
	float sum = 0.0;
	float size = 1.0;
	float i;
	for (i = 0.0; i < it; i += 1.0 )
		 sum += (float) STREE_snoise((size*p) + (STREE_snoiseV(size*p)*freq))/size;
		 size *= 2.0;
	return(sum*1.4);
Mark
Guest xionmark
I've attached all the old ShadeTree include files ... hope Reid doesn't object ....
Mark
