Broken Delete COP in Houdini 6
I figured I'd ask if anyone can verify this.
The Delete COP in Houdini 6.0.243 seems broken, at least it doesn't work the same as 5.5.
In 5.5 Delete removes the specified planes completely. In 6 the planes aren't removed. If you use it on a C plane the pixel values will be 0 but the plane is still there, if you use it on A the pixels are set to 1, but the plane is still there.
Can anyone verify this? I'm not crazy, right? The Delete COP isn't supposed to function this way.
