getting neighbours in python
friedvinyl
hey guys, just wondering if there is a python equivalent to the vex getneighbours function. i'm trying to get a list composed of a set of two points that make up each edge.
as of right now i'm using the "pointneighbours" hscript function through "hscriptExpression", which works great for closed objects where points that share an edge also share two primitives. unfortunately, if i'm trying to get the edges of a polygon curve, or an object that has an open edge, that approach no longer works since points that make up certain edges don't necessarily share two primitives.
of course, if there's an easy way of getting edge info that'd be fantastic. hou.edges()? (or a way of splitting each edge of a curve into a primitive on the sop level)
(running 9.5)
  • 2 weeks later...
