how to rotate around a axis in point instance?
have u tried using a point sop, and changing the normal direction?
do you specifically want to enter degrees or radians ?
is this instance from a POP network ?
it is easy to randomise the rotation in Y axis with copy stamp. how to do this in point instance?
yes, I tried point sop with adding normal, it seems to "direction", not "degrees to rotate around an axis".
it is not a instance from a instance pop.
Here is the file which I wanted to make with point instance, but it is made with copy sop now.
bb.hip
Edited by ykcosmo
