paleajed Posted August 16, 2008 Share Posted August 16, 2008 (edited) In the following .hipnc file, I have a setup with a sphere-shaped particle fluid, that should flow into a letter G-shaped attractor. I use a popnet with attractor that uses a point sop (/obj/geo/point1) as its force description with a radial force. Then I bring all of it into the particle fluid solver through a pop solver. The particles do not move. What am I doing wrong ? *** the problem is solved fluidlogo.hipnc Edited August 19, 2008 by paleajed Quote Link to comment Share on other sites More sharing options...
