arcLength
Hi. I want to know the arc length of the curve segment inside geometry shader. But mantra got crash.
GU_Detail *gdpCurve = new GU_Detail;
gdpCurve->copy(*gdpSkin);
GU_PrimRBezCurve *shaft = GU_PrimRBezCurve::build(gdpCurve, 1, 4, 0, 0);
int ind1, ind2;
GU_Curve *temp = shaft->cut(0, 1, ind1, ind2, 0);
GEO_Curve *test = (GEO_Curve*)temp;
float size = test->arcLength(0.1,0.5, 0, 1);
or
GEO_Curve *test = shaft ->getCurve();
float size = test->arcLength(0.1, 0.5, 0, 1);
Ok, guys. Something awful.
const GU_Detail *cgdpSkin = new GU_Detail;
cgdpSkin = queryGeometry(handleSkin, samplesSkin);
GU_Detail *gdpSkin = (GU_Detail*)cgdpSkin;
GU_PrimNURBCurve *shaft = new GU_PrimNURBCurve(gdpCurve);
shaft = GU_PrimNURBCurve::build(gdpCurve, 4, 4, 0, 1, 1);
float start, end;
shaft->validRange(start, end);
std::cout << "start: " << start << " end: " << end << std::endl;
float arcLenCurve = shaft->arcLength(0, 1, 0, 10);
std::cout << "arcLenCurve: " << arcLenCurve << std::endl;
UT_Vector4 testpos;
int test = shaft->evaluatePoint(testpos, 0.5);
std::cout << "test: " << test << std::endl;
std::cout << "x:" << testpos.x() << " y:" << testpos.y() << " z:" << testpos.z() << std::endl;
And all results:
start: 0 end: 2
arcLenCurve: 0
test: 0
x:0 y:0 z:0
Bad results. I want to take curve from sops and to create the same curve into my procedural. And than to calculate length of this curve and lengths of its segments.
Does anyone know what is wrong?
Thanks
