Aearon Posted October 15, 2008 Share Posted October 15, 2008 hey guys, but apparently fbx files can be read using the file sop, but not using gconvert. before i was under the impression that the file sop and all other ways to read geometry in houdini use the table defined in the GEOio file and that's it. i guess the fbx stuff doesn't use a command line tool and is compiled into the file sop or something but not into gconvert. don't you think it should be in there as well? i need this for exporting individual objects per file, fbx is nice because it sort of exports per vertex normals from max by splitting polys. Quote Link to comment Share on other sites More sharing options...
