importing camera and geometry data in Houdini
alessio
Hi there! :)
I'm having problems importing camera and geometry data from pftrack and syntheyes into houdini. The matchmoving software exports a .geo file and a cmd file. When I run the script
using a typical windows path (ex: D:\Folder\...\....\file.cmd) houdini output an error saying "Source failed, D:\Folder does not exist".
I then copied all the exported data into a folder on my desktop, and tried to run the script using the Desktop icon in the "Select File...\Locations" window. So when I select the file from here houdini can import the camera and locators (but not the geo or the sequence image to use from COPs as a backgroud... :blink: ...) but I noticed that it puts the variable $JOB in front of the path (ex: $JOB/Desktop/.../file.cmd).
Can anybody tell me what I'm doing wrong?
Thanks so much!
Cheers,
Alessio
EDIT: ...ok, now I have the plate in the background. I've created a new copnet (at scene level) and read the seq from here. This way it works...uhm...but if I create the copnet at image level houdini says that can't read the files...
Edited by alessio
Hey Alessio
Welcome to odforce!
$JOB is a environmental variable used within houdini, this is setup under ur "alias and variables menu" (under EDIT)
- then under Variables
so if u set this to fill in what is missing when refering to $JOB/Desktop/.../file.cmd
if the path is actually c:/my computer/Desktop/../file.cmd
Then ur $JOB needs to be = c:/my computer/
excuse my lack of windows knowledge, but this is cross platform, cause essentially when the script is launched it will substitute the $JOB with ur entry to make up the whole line as it should be :$JOB/Desktop/.../file.cmd = c:/my computer/Desktop/../file.cmd
Hope this fixes the problem
