line from add sop to wire object ?
e=mc^2
hey
I have new problem;)
I have two animated objects(animated in DOPs), I deleted almost all points except one in first and second object, then i created line with add sop from these two points(animated line) but after for example 20 frames I want that this line will be wire object, how can I do this?
The problem you have is recursion. You can't have a curve built outside of the sim then fetch that curve back in.
The best way to handle this is to create a new DOP geometry object and pass the two other DOP objects' geometry in to a SOP Solver where you build your curve. Then you can create a wire object at whatever frame you want from the geometry in that DOP object.
All kept in DOPs. No recursion issues.
