Baking Point Clouds from RSL
I am unable to generate a point cloud file from an RSL shader within Houdini to be used for SSS. I may be using the wrong workflow but when I render out my RIBs from the renderman ROP, the RIB file is created successfully but it is not generating the .ptc file.
The shader I have applied to my geometry to bake out a .ptc file is as follows:
surface bake_radiance_t(
string filename = "$HIP/maps/sss.ptc",
displaychannels = "_area,_radiance_t";
color sc = 1)
color irrad, rad_t;
normal Nn = normalize(N);
float ar = area(P, "dicing");
/* Direct Illumination (ambient and diffuse) */
irrad = sc * ambient() + diffuse(Nn);
/* Store in point cloud file */
bake3d(filename, displaychannels, P, Nn, "interpolate", 1,
"_area", ar, "_radiance_t", irrad);
Oi = Os;
Ci = irrad * Os;
Are there any specific settings I have to apply in Houdini for ptc's? Thanks in advance for any assistance to resolve this!
Sam.
