superdjo Posted March 17, 2009 Share Posted March 17, 2009 Hello, I'm finishing up an otl and going through the pragmas in vex to create a better parameter interface than just stacking up params on top of each other. Basically I've read the houdini docs on pragmas and I do not see some kind of solution to get a seperator the way you can have it when editing the parameters of the otl through the parameter tab of the operator type window . I've tried adding them through the edit parameter interface but it's only for that instance of the node. When I create a second node... no more separators Grouping is good but I still need some space in the stack of parameters I have. Anybody has a solution to this ? Quote Link to comment Share on other sites More sharing options...
