pclaes Posted April 11, 2009 Share Posted April 11, 2009 (edited) you don't need to use Pbr, Hdri was just meant in the sense of adding more environment. Have a look at the following images, they are with different highlights/environment, it shows the importance of having some more things to reflect in the scene when doing rendertest with reflective/refractive objects. I built a mockup liquid test, the motion is a hack with particles, but perhaps the hip file helps to explain better what I meant in the above post. Some of the nodes have comments on them, if you want to render it, you'll have to write out the geometry again, should be fairly quick. Check out the highlights in some of these videos: http://www.youtube.com/watch?v=B3cLc6et868 IOR table: http://www.3dtotal.com/team/Tutorials/hdri/ior_table.jpg highlights_03.hip Edited April 11, 2009 by pclaes Quote Link to comment Share on other sites More sharing options...
few_a_fx Posted April 11, 2009 Author Share Posted April 11, 2009 you don't need to use Pbr, Hdri was just meant in the sense of adding more environment. Have a look at the following images, they are with different highlights/environment, it shows the importance of having some more things to reflect in the scene when doing rendertest with reflective/refractive objects. I built a mockup liquid test, the motion is a hack with particles, but perhaps the hip file helps to explain better what I meant in the above post. Some of the nodes have comments on them, if you want to render it, you'll have to write out the geometry again, should be fairly quick. Thanks pcales. I'll definitely check out the hip file. I'll post more updates as soon as I can...hoping to get this done soon. Quote Link to comment Share on other sites More sharing options...
pclaes Posted April 12, 2009 Share Posted April 12, 2009 here's a rendered movie, the movement isn't really there, but it does convey a bit of the look: water_highlights_01.mov Quote Link to comment Share on other sites More sharing options...
few_a_fx Posted April 14, 2009 Author Share Posted April 14, 2009 I tried out the hip file you attached pclaes, wasn't able to get the motion I wanted. But I went back to a previous file where I used a similar method, but it ended up have the same motion. So I'm sticking with the particle fluids. Here's my last render. wfx.mov Quote Link to comment Share on other sites More sharing options...
